96 Jimmy - no voltage to fuel pump?
I hope you guys can help...I am replacing a dead fuel pump and before I put the tank bank on, etc. I checked the voltage going to the pump (at the pump connection point) and I am not picking up anything. All fuses are good - is there anything else that would cause no voltage to reach the pump? Are the 3 relays in the glove box supposed to be the exact same? There isn't a label on the cover stating what they control.
Also, when I turn the jimmy to "on" while testing the voltage, the fuel gauge display shows WAY past a full tank. The fuel level sender is not connected. Not sure whats up with that.
Thanks...
Thanks...
RJWolfe
02-17-2019 07:32 PM
sick s10 blazer
06-13-2012 10:03 PM
NV4x4BLazer00
03-10-2012 08:57 PM
2001Blue
12-31-2010 12:16 PM
