Low voltage at fuel pump
Old Jun 11, 2012 | 08:54 PM
sick s10 blazer's Avatar
sick s10 blazer is on a distinguished road
Default Low voltage at fuel pump
I have a 95 S10, Vortec v6,4.3,4door, 4 wheel drive. It has low fuel pressure. With a brand new Bosch pump in. So I ck voltage at pump. Its only 8.6 volts. Everywhere else I ck I get 12. What am I missing????
Old Jun 11, 2012 | 10:14 PM
Just a friendly FYI: aftermarket fuel pumps are NOT recommended on 4.3L Vortec engines, AC Delco or Delphi only, unless you like changing the pump
When the ignition is turned to the RUN position, (engine off) the fuel pump is only energized for 2 seconds, so you must check voltage during that 2 second time frame. Have you checked resistance from the fuel pump module electrical connector to ground? Must be less than 5 ohms. Which style connector is on the pump module?
Old Jun 12, 2012 | 07:06 PM
My connector is only a 3 wire. At key turn on I do get the 12+ v. But resistance is around 30.
Old Jun 12, 2012 | 07:33 PM
My bad, 1995, sorry. 30 ohms is too much resistance in the ground circuit, (probably what toasted the old pump). Solder on a 14 gauge piece of wire at the module connector and run it to a good, clean, body ground.
Old Jun 13, 2012 | 10:03 PM
Capt. Hook. Thank you very much. Did that tonite. 1ohm. Hopfully this all works out. Darn tired of droppin that tank.
RJWolfe
Feb 17, 2019 07:32 PM
NV4x4BLazer00
Mar 10, 2012 08:57 PM
2001Blue
Dec 31, 2010 12:16 PM
cjp5
Sep 15, 2010 07:51 AM
c4gibson
Apr 4, 2008 10:49 AM
