96' model hood washers
Old 03-27-2017, 09:29 AM
Graveyard's Avatar
Graveyard is on a distinguished road
Default 96' model hood washers
Good Morning,
I know we have covered this in the past but I couldn't find the thread.
Simple question really, Are the new washers just a lock washer or is it something the should be purchased from the dealer.
And the issue is noise from the hood pivot arms. It sounds like it comes from the dash...
Thanks
Old 03-27-2017, 10:55 AM
Tech Article section...
Hood Hinge Rattle - TSB 01-08-63-001B
The washers themselves are not lock washers, they are belleville washers that put somewhat constant pressure on the hinge connection to keep it from rattling without binding up the hinge.
Old 03-27-2017, 03:58 PM
Graveyard's Avatar
Thanks Swartlkk,
So, I called my local chevy dealer today...no longer available. Is there anywhere to get the dimensions of the washer? McMaster-carr.com has an assortment of belleville spring washers for like 3-5 bucks for a package of 12. Beats the hell out of 3.49 plus 8-12 dollars shipping.
The bolt actually looked to me to be maybe an 8mm thread. Anyone got one laying around?
Thanks and Later
Old 03-27-2017, 04:20 PM
I don't recall anyone posting measurements in the past. If I still had an s-series, I'd do it. Your best bet is to pull the bolt and measure it.
You want the washer to fit up on the larger shouldered section on the bolt. The OD should match the washer face of the bolt head or the nut itself (whichever is larger). Almost as important is selecting the appropriate deflection load. Too light on the load and the hinge will still rattle. Too heavy and you could bind up the hinge and end up bending the hood.
If I remember correctly, the washers were quite thin, definitely below 0.06" in thickness and I'd guess somewhere in the 0.032"-0.039" thickness. Load will depend on material thickness as well as the h/t (amount of angle or cone to the washer).
Old 03-28-2017, 12:04 AM
Rock18's Avatar
Rock18 is on a distinguished road
Dealer was mistaken -- I just got them like 2 weeks ago at $4 a pop from a local Chevy dealer. Yes, it expensive for what amounts to two custom washers but well worth it to quiet that infernal racket.
GM Part # is 12383460. They are available on eBay and from GM dealers, PM me if you still have trouble finding them.
Old 03-28-2017, 05:58 AM
Graveyard's Avatar
I stopped by our True Value store yesterday and picked up (2) 12mm wavey spring washers. They fit right onto the shoulder and corrected the problem....so far.
I'm out $1.06 for two pieces.
Later
Old 02-16-2019, 03:58 PM
JonD's Avatar
JonD is on a distinguished road
Default Only 95’ and a Over?
I’ve got a 94’ Sonoma with this exact same issue. Why does this not apply to my model year?
Old 02-16-2019, 08:56 PM
Rock18's Avatar
No idea. It sure looks like it ought to.
It's only a few bucks worth of parts though, so if you're having the same issue it's worth a try.
TDS-MN
11-18-2018 06:18 AM
teddybeer21
06-21-2011 03:04 PM
jsmz
10-17-2008 01:37 AM
gserve
12-03-2006 10:29 PM
Quick Reply: 96' model hood washers
