98 Blazer problem starting
I have a '98 Blazer with over 120,000. It will not start after driving for a long time, about an hour. It will start after cooling off for 30 - 45 minutes. The last time it did this I noticed that I couldn't hear the fuel pump running when turning the key on. I waited about 5 minutes and turned the key on and could hear the fuel pump, then it started. I also read that low oil pressure could stop the fuel pump from running. Is this true?
Thanks
Thanks
RE: 98 Blazer problem starting
The fuel pump is going. Replace that before it doesn't start at all. Install a new fuel filter while you're under there.
cgrett
11-15-2010 09:08 PM
Sprocket
03-20-2008 09:39 PM
lukewb
14
12-02-2006 02:23 AM
