Bravada transfer case to Blazer case
My brother has a 1997 Bravada with the constant 65/35 split AWD system. The transfer case pops so he took the front driveshaft off. I just found out that that is real bad for those transfer cases. We are going to swap to a Blazer manual transfer case so it will be a good setup (Bravada diff/axle tube setup with a Blazer T-case). We found a 1986 Jimmy with a manual transfer case in a pick n pull yard, WILL THIS WORK?? I will get the transfer case, and floor shifter console piece/lever. I realize we will have to cut the front of his flow through console off but we just need to know if the transfer case will bolt up.
Flyfishen
06-18-2019 11:22 AM
Jonathan J. Janacek
05-08-2014 07:20 PM
BadA$zBravada98
03-21-2011 02:25 PM
oshkosh
09-04-2009 10:30 AM
