Coolant plugs - location on engine block??? 4.3l '97
Old Feb 12, 2010 | 07:13 PM
helo's Avatar
helo is on a distinguished road
Default Coolant plugs - location on engine block??? 4.3l '97
Anyone ever taken these plugs out?
Where's the passenger side plug? It seems like it should maybe be behind the starter, but I don't feel anything there or see anything in that vicinity. Help, please?
My hayne's book mentions a pair of coolant drain plugs on each side of the engine block. I read a rumor somewhere that there is a knock sensor in place of the passenger plug for some engines, but I don't see that either! I found a thread with the same issue from Apr2007, but it obviously isn't specific enough for me https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/coolant-plug-s-engine-block-9910/
I think I found the driver's side plug behind the tail end of the exhaust manifold near the start of the Y-pipe (a 9/16" bolt) but haven't pulled it out because I couldn't find the second plug. I also had difficulty getting a wrench in there (I might remove the wheel fender). My coolant is _old_ with a tinge of rust, so I'd really like to get both plugs out and flush her good.
As I write this, my engine sits in pieces. I started an intake manifold gasket replacement today. My uncle insists I should have just used stop-leak, but I'm not too keen on that. My plan is to do a flush after I get her back together and running. Info will be much appreciated.
Old Feb 12, 2010 | 07:36 PM
This image should help:
Attached Thumbnails Coolant plugs - location on engine block??? 4.3l '97-240.jpg
Old Feb 12, 2010 | 11:01 PM
helo's Avatar
fo' shizzle. That's a really useful pic. Thank you.
Old Oct 4, 2013 | 06:04 PM
Emu's Avatar
Emu
Emu is on a distinguished road
Here is a imgur link to the picture above. 1997 Blazer Coolant drain plugs on block - Imgur
Old Oct 28, 2019 | 05:35 PM
Wartang's Avatar
Wartang is on a distinguished road
So is there an easy way of getting to the plug on the passengers side without removing the engine, which is beyond my tools
Old Oct 29, 2019 | 07:56 AM
IIRC, pulling one plug will drain both sides. I wanted to do the same thing you're doing but when I took out the second plug, nothing came out (and I even stuck a screwdriver in there to be sure it wasn't just clogged).
Jamaroon
Sep 20, 2015 01:20 PM
lil_blazin
May 10, 2009 05:20 PM
N.alaska_blazer
Feb 23, 2009 01:31 PM
jimmieb
Nov 13, 2007 02:29 PM
kerander
Apr 12, 2007 04:29 PM
