Changing the headlight bulbs on a 97 Blazer
Can anyone tell me how to change the headlight bulbs on a 97 Blazer? Thanks!
RE: Changing the headlight bulbs on a 97 Blazer
do you have your owners manual?
Yes-
Will it tell me how? Looks like I need to pull out the grill.
For composite headlamps:
For sealed beam headlamps:
The '97 is one of those years that a lot of people ask questions about. If you have the composite headlamps and wouldn't mind snapping some pictures of the plastic caps and the retaining pins, I'm sure that would help out a lot of people in the future! Thanks!!
*EDIT* - Also listed in the owner's manual page 6-33 thru 6-35.
Remove of Disconnect:
1. Plastic Caps that cover the headlamp retaining pins.
2. Headlamp retaining pins.
3. Headlamp from the vehicle.
4. Bulbs from the headlamp by pushing in and rotating them 1/4 turn counterclockwise.
Install or connect:
1. Bulbs to the headlamp by pushing in and rotating them 1/4 turn clockwise.
2. Headlamp to the vehicle.
3. Headlamp retaining pins tightened to 62 lb.in. (7 N-m)
4. Plastic caps that cover the headlamp retaining pins.
Install or connect:
Remove or Disconnect:
1. Screws that retain the headlamp retaining ring.
2. Headlamp retaining rings.
4. Headlamp electrical connector.
Install or Connect:
1. Headlamp electrical connector.
3. Headlamp retaining rings.
4. Screws that retain the headlamp retaining rings.
Install or Connect:
dropd4door
01-30-2006 06:18 PM
