Hood Latch adjustment ?
Old 09-21-2007, 11:21 AM
03RedBLazerXtreme's Avatar
03RedBLazerXtreme is an unknown quantity at this point
Default Hood Latch adjustment ?
Is there any adjust ment to the hood latch......
I have a 2000 S10 pickup and i am replacing the dented
hood with one from a 2001 S10 Blazer...............
Should be a simply swap.. but my hood latch isnt lining up
Any adjustments to the latch.... or ... some other place ?
any help is appreciated ~ ~ Dw...............
Old 09-21-2007, 11:43 AM
Default RE: Hood Latch adjustment ?
You should be able to loosen the bolts and move it up/down to line everything up. You will also have to move the outer bump stops either up or down to line the hood up flush with the fenders. Everything should be the same between the two vehicles.
Old 09-21-2007, 11:55 AM
thanks ~ ~
edit ~ ~ ~>
in new post~>
Old 09-22-2007, 12:25 PM
ThanksKyle
I found the left to right adjustment.. by taking the whole bracket off
and turning it over and loosened them nuts.. and got the hood to close and re
open better ~ ~ Darrell ~
Old 09-22-2007, 05:46 PM
Great! Glad you got it all fixed up!!
Old 09-23-2007, 03:31 PM
Yup.......... never needed to adjust the hood b4........ ! Darrell ~
92WildBravada
07-29-2008 09:29 AM
mtfirejohn3
10-20-2007 04:23 AM
blazer4x4
09-12-2007 11:59 AM
JST4SHO
04-29-2007 04:33 PM
Blazenfast
10-15-2006 09:53 PM
Quick Reply: Hood Latch adjustment ?
