ignition lock cylinder
Old 06-06-2007, 11:05 AM
Booztd's Avatar
Booztd is an unknown quantity at this point
Default ignition lock cylinder
i have a 97 blazer and i think i need a new lock cylinder cause it is hard to turn the key and it doesn't go into the lock position all the time. luckily my key is worn enough to pull it out. but my question is once i install the new lock cylinder, do i have to relearn the ECU for the new cylinder? i have an aftermarket alarm w/remote start. i heard something about the passlock system but i don't know if that applies to me. thanks
Old 06-06-2007, 11:13 AM
hillbillyinOhio's Avatar
Default RE: ignition lock cylinder
noting will change with your alarm/remote start, because you are lucky like me and have no passlock on your truck. It started in 1998. as for the reprogramming of things, Im not sure.
Antne
08-29-2014 05:59 PM
maepis
12-12-2011 04:32 AM
Hammond1524
04-23-2011 03:46 AM
Licklog
05-24-2010 10:21 PM
rockettme
08-13-2007 12:42 PM
Quick Reply: ignition lock cylinder
