MAF,,,or MAP sensor. Wich is it
I want to clean my sensor. I tried going to the part's store to see what one looked like. None of the big3 chain store's hasthe "MAF" sensor you guy's are saying to clean. The have a "MAP" sensor. Are they one in the same. My car is a 95. I looked at the write up's on how to clean them, but the pic's no longer work. Thank's.
Here's a pic. Wich one is it. I tried to edit the pic with arrow's, but I can't seem to find my arrow thingy.
[IMG]local://upfiles/11981/28B997A26B7A4E268580D2C765182F95.jpg[/IMG]
RE: MAF,,,or MAP sensor. Wich is it
The CPI motor used in your truck does not have a MAF sensor. I would just do a thorough cleaning of the throttle body, removing the IAC valve (above the throttle body pointing towards the passenger side of the motor) and cleaning inside there as well.
ORIGINAL: swartlkk
I cleaned the tb tonight, and then ran out of day light. I'll clean the IAC valve tomorrow. I'm trying to get rid of a hesitation that sounded like what guy's are describing as maf sensor issue's.
Thank you Sir!
buschmaster
03-13-2012 09:10 AM
Diverknox
12-06-2009 11:48 PM
Bad Ramer Jamer
09-12-2008 06:55 AM
