Need help
Need help
I have a 2000 Chevy Trailblazer. Recently the blower motor stopped working along with the the electric windows in all doors except for drivers door, which is the only door that will work all windows. Any ideas ???
Check the window lock switch on drivers door panel above window switches. Mine went out and I spent 3 days going thru wiring diagrams. If you have manual non computer controlled temp controls you can check blower motor relay on firewall. There is a thread on here somewhere that also tells you how to check the resistor that control fan speed. you can check the motor by bypassing it straight to battery. if you have computer controlled temp unit it’s a major pain
ncoull
04-20-2012 09:26 PM
Ryan2237
04-12-2011 11:35 AM
