No pickup speed on express way
Old 07-26-2009, 04:03 PM
breakyadown89's Avatar
breakyadown89 is on a distinguished road
Default No pickup speed on express way
When i am on the express way going about 45 mph and i floor the gas pedal to get around a car there is no pickup speed and instead the rpms get real high and hits redline. is this normal? also there is a poping noise in the front end when i accelerate at a stop what is this. thanks
Old 07-26-2009, 08:19 PM
Sounds like you may have a problem with your transmission.
As far as a popping noise when you accelerate, I would inspect the front suspension. Look for cracked bushings on the lower control arms and/or broken sway bar end links. Jack up the front end to get the tires off the ground and support the front end of the truck with jackstands under the frame. Take a 2x4 and put it under one of the front tires. Lift the wheel up. As you do so, watch the lower control arm. If you lift the wheel up some and the lower control arm does not initially move, the lower ball joint on that side is bad. You can check the upper ball joints with a pry bar by removing the wheel and trying to pry up on the upper control arm between the steering knuckle and the control arm. If you get movement here, the upper ball joints are bad.
Old 07-26-2009, 10:15 PM
96chevblazer's Avatar
My dads 96 does the same thing, but it has 200k on her so its expected
Old 07-27-2009, 12:27 AM
xCHIPx's Avatar
xCHIPx is on a distinguished road
I have the same problem but besides the front end its my back end but I know why it cracks.
So its a transmission problem?
Old 07-27-2009, 09:18 AM
so would you guys say it is normal? But once it hits redline it shifts to the next gear. but without the extra power. I cant even pass up anyone on the express way when i floor it. I was also told that my popping noise was most likely the u joints. is this true and what could happen if i do have bad u joints
Old 07-27-2009, 11:08 AM
rriddle3's Avatar
Originally Posted by breakyadown89
When i am on the express way going about 45 mph and i floor the gas pedal to get around a car there is no pickup speed and instead the rpms get real high and hits redline. is this normal?...
so would you guys say it is normal?...
No. Have the transmission checked.
10-78 edac
04-21-2013 03:53 PM
10-78 edac
04-13-2012 11:17 PM
mykeboy01
Street N Strip
11-07-2011 02:15 PM
maki3242@gmail.com
07-24-2008 06:40 PM
Jimmysls98
02-28-2007 10:40 PM
Quick Reply: No pickup speed on express way
