Parts
Old 12-07-2017, 07:22 PM
Brian0220's Avatar
Brian0220 is on a distinguished road
Default Parts
What vehicles and years can I use for parts on my 2000 s10 blazer? I am wanting to buy a parts truck.
Old 12-07-2017, 09:36 PM
chevyriders's Avatar
98+ is going to be more or less the same. There are some minor differences between years, but nothing that I would consider to be serious.
98+ gmc jimmy will be the same with the exception of grille/headlight/bumper/rad. Support.
Bravada is also the same, with the exception of being awd, and again the front body parts.
There were options that could be different even in the same years... 4 button transfercase as opposed to 3 button, different interiors, trim packages, different gear ratio axles, zr2 suspension package, zq8 suspension package, xtreme edition, etc
You can also use the drivetrain and most body parts off s10/Sonoma pickups. Just make sure they have the 4.3 if you want to be able to use the engine/tranny.
Old 12-07-2017, 10:35 PM
oldeerslayer's Avatar
oldeerslayer is an unknown quantity at this point
Your best bet for a parts truck is 98,99,00 Blazer with same number of doors and same drive train (2 or 4wd). Nearly everything would be the same except the 98 steering wheel.
01 up has a different VCM/PCM. Mid 02 radios changed to double din.
As ChevyRiders said there are many others with parts that will fit.
Old 12-08-2017, 09:05 PM
Brian0220's Avatar
Thanks!!
Old 12-08-2017, 09:07 PM
Brian0220's Avatar
Default Thanks
Thanks for the help!!
IrishChachi
02-26-2016 12:00 PM
helipinch
11-26-2015 12:20 AM
tibby
12-26-2011 08:22 AM
zcat23
09-29-2010 10:30 AM
lionel2
17
02-13-2008 04:23 PM
Quick Reply: Parts
