Stubborn Crank, No Start
george
Had this exact issue in my 99 Blazer. Ended up fixing it eventually, after a lot of wasted money on parts. Come to find out the fuse box and particularly the lower level where the red honeycomb section where the wiring harness ties into the underside of the fuel pump relay. The power wire for the fuel pump was corroded and had burned up a little and was not making a good connection. Cleaned it up and tied it back in. Starts every time and haven’t had an issue since. This was over a year ago.
If you do not have power to the input of the ECM fuse then you don't have an ignition problem you have a power problem. When you go to key on/run does your dash respond or any other evidence that your ignition switch is providing run power to any system in the truck? What is your battery voltage?
George
George
The ECM I circuit seems to be the only one effected. Fuel pump cycles batt gauge moves but the others are dead. No gear indicator lights come on either I think I read trans is on that circuit as well. Batt has 12.1V
