What brand intake gaskets should i get?
i have a 95 S10 with a vortec "W" vin and i have to replace the intake gaskets. what brand should i get? Felpro? GM? Victor reinz? corteco?
whats the differece between brands?
thanks so much
thanks so much
Victor reinz was sent with my engine and have no problems
is this with your latest engine that you have? or the one before that had the timing jumping around?
also did you ever replace the distributor gear or the intake gaskets with that motor that had the timing jumping around all over the place? thanks
both engines came with the reinz gasket set..installed all new gaskets..never had to mess with the dist. gear...timing variations is normal
I couldn't tell you about the differences between them, but I used the felpro set on my lower intake a couple of years ago. Probley got at least 30,000 miles on since. No leaks yet.
just curious, if you were looking at the intake gasket, was the center piece missing from the two siamesed ports on the gasket? if you look up the intake gaskets for a 95 S 10 vortec "W" vin , it shows a gasket with the center divider missing, why? wouldnt that cause a leak?
reeladdiction
10-08-2011 04:02 AM
latinoNJ
07-06-2010 12:15 AM
bigdaddykane93
02-10-2010 09:19 AM
94blueknight
Headers, Intake, & Exhaust
10-19-2008 03:15 PM
