01 blazer 4wd 3 button
Old Jun 5, 2020 | 04:25 PM
sdjames79's Avatar
sdjames79 is on a distinguished road
Default 01 blazer 4wd 3 button
Where does the vacuum line from the actuator under the battery go to. I can only find diagrams of the 4 button. I know it is on here somewhere but for the life of me I cannot find the 3 button diagram. Damn thing popped off and cannot find where it goes!
I appreciate any and all help! Its 110 out with humidity and i am having a brain fart.
Thanks!
Old Jun 5, 2020 | 08:59 PM
okaussie's Avatar
okaussie is on a distinguished road
It runs from the front axle actuator back to the transfer case switch on the top of the transfer case. It is mounted on a plastic three nipple connector that is keyed and then is pressed on the switch.
Bill
Old Jun 6, 2020 | 11:40 AM
sdjames79's Avatar
Bill
Thanks! Will it just slide back on the nipple? It also looks like it has some kind of check valve or maybe its a splice. Replaced the top lines before when 4x4 did not work and a/c would not switch to defrost. I am going to replace the whole line looks like its a dry rotted mess. Have to wait for a cool day still pushing over a hundred with humidity.
Old Jun 6, 2020 | 12:29 PM
okaussie's Avatar
Based on your mileage and other issues with the vacuum system that the S Series platforms have, you also might consider replacing the transfer case switch as well when you do the hoses. I would also replace the one way valve as well as the front axle actuator.
If tranny fluid infects the vacuum system, it will tear up the switch, valve , front axle actuator diaphragm , as well as the vacuum lines.
And yes, the hoses just slide onto the nipples of the transfer case switch. That connector is keyed so make sure when you reattach that nipple connector it mates up perfectly with the transfer case nipples or you will have 4wd issues.
Bill
Kaegael
Apr 6, 2014 09:57 AM
chitown906
Oct 29, 2013 11:49 AM
Teleutesl
Oct 2, 2012 06:59 PM
shopcarpro
Jan 5, 2011 03:54 AM
cwiththehad
Aug 4, 2007 12:00 PM
