01 blazer A/C playing up need help
Old Apr 2, 2010 | 06:49 PM
filoblazer's Avatar
filoblazer is on a distinguished road
Default 01 blazer A/C playing up need help
hi
today went for a drive on my blazer, then suddenly the aircon started getting warm. i turned the aircon off for couple of minus still no go. After 20 minus turned it on and it work, when i reached home it was still cold.
went out after 3 hours, it happened again (warm) ive regas the aircon 6 months ago anyone know whats wrong with it?? how to fix it?
thanks
Old Apr 2, 2010 | 06:50 PM
filoblazer's Avatar
Anyone here had it happen on there blazer??
Old Apr 2, 2010 | 07:39 PM
filoblazer's Avatar
went and started the aircon again it worked, i realised the compressor where it spins for the aircon wasnt spinning, after couple of on and off it started spinning. we checked the pulg where the compressor is it had no power. could this make it not click over to work?? how do you fix it?
Old Apr 2, 2010 | 09:50 PM
filoblazer's Avatar
btw whats the plug that has a blue colour in it.
Attached Thumbnails 01 blazer A/C playing up need help-p1040320.jpg
Old Apr 3, 2010 | 01:50 PM
1998MSO's Avatar
1998MSO is on a distinguished road
Most likely the refrigerant is low. The pressure switches shut down the power to the compressor if this is the case. After you let it sit awhile, the pressure equalizes and it will work again, for a little while anyway.
Old Apr 3, 2010 | 02:15 PM
LuvMyTJ's Avatar
Holy quadruple post Batman!
I also will vote for low on refrigerant. As stated above, it will not cycle if it is low. There are gauges available to check it, or just buy a can with the gauges and CAREFULLY check/add it. Be careful connect to the correct port (low side), you don't want to mess with the high side.
Old Apr 7, 2010 | 05:54 AM
filoblazer's Avatar
Thumbs up
thanks guys fixed the prob needed regas
IrvJr
Apr 10, 2011 04:41 PM
JTalley
Feb 4, 2011 02:18 PM
beyondbasic
Jan 10, 2011 02:55 PM
MintyMadness
19
Feb 14, 2010 12:12 PM
laserblazer
Jan 26, 2007 02:16 PM
