01 blazer fuel gage weared
Old Feb 11, 2013 | 10:18 PM
igs4dragon8's Avatar
igs4dragon8 is on a distinguished road
Default 01 blazer fuel gage weared
my gage is reading wearied it is not updating right, i can place the transmission in nutrual and it will update and read right,
Old Feb 11, 2013 | 11:04 PM
Rumblur's Avatar
Rumblur is on a distinguished road
The sending unit is made onto the fuel pump, in the tank. This is a VERY common problem. Basically the 'fix' is to replace the pump, which you will need to do eventually sometime between 100k miles and 150k miles.
Old Feb 12, 2013 | 12:31 AM
step66's Avatar
X2 to Rumblur-in my experience these gauges are very inaccurate,regardless of pump/sending unit age. My current 97 had had the pump replaced prior to my owning it,and can never trust the gauge;when I fill it I "use" 1/4 tank in the first 40 miles,then the use rate slows to about what would be considered normal until it reaches about 1/3 then dives into the red zone in another 40 miles! After fueling I always find that about 5 gallons remain in the tank.I always go by mileage,after 325 miles I fill it and usually get 12-13 gal. in the tank(I live in flat terrain and get very good mileage out of my Jimmy-22 to 24,even as high as 16 in 4x4) I'd probably replace the pump soon if it was mine!
Old Feb 12, 2013 | 03:58 AM
Rumblur's Avatar
I base my advice on my own experience, that's all I really know. I bought my 2000 Blazer and the gauge was all over the place, bouncing around and inaccurate. I replaced the pump and with it the sending unit as it is part of the unit, and my gauge was perfect after that. No bounce, accurate reading and stable. I will advise though that when I bought my pump, there are 3 totally different models - 2dr, 4dr and S10 pickup... and using the wrong one could have ill effects.
Old Feb 12, 2013 | 11:30 AM
New pump, the pump is not evean 4 a blazer. It was one I had for my moms 05 calavlear. Just needed to change connecter on pump. It is just funny that it is the sending unit, I think it is the computer or cluster that has gone nuts
Jerry.rm125
Sep 4, 2014 02:45 PM
igs4dragon8
Oct 3, 2012 03:30 PM
Nelubez
Feb 26, 2009 02:08 PM
d666
Nov 13, 2008 09:25 PM
NCStone
Jul 15, 2006 02:52 AM
