Weared cold starts
Old Oct 1, 2012 | 10:53 AM
igs4dragon8's Avatar
igs4dragon8 is on a distinguished road
Default Weared cold starts
01 blazer runs fin wean it finely gets started.
pump pushiness good fuel pressure 50psi
will crank on jump
battery passes autozone tester
will try to post video
Old Oct 1, 2012 | 10:59 AM
Lanny's Avatar
Lanny is on a distinguished road
You need 60 psi to start...do leakdown test if money is an issue start with the fpr if not go straight for the spider assembly ...good luck
Old Oct 1, 2012 | 03:19 PM
i just got back from oralies and the pump sets 53-54 psi but leaks down to 50 in about 10 mins
how do i test the fpr?
Old Oct 2, 2012 | 07:30 AM
Lanny's Avatar
Open the Plenum. Look for washing. Washing on the passenger side indicates a leaking fpr. Washing on the driver side indicates a leaking nut kit.
For giggles before you do any of this replace the fuel filter if you have not already. Sometimes its the little things.
Old Oct 2, 2012 | 09:22 AM
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
53 psi is acceptable, and only leaking down to 50 over 10 min indicates that there isnt a leak going on to worry about. Also when the FPR leaks with my experiance it makes cold starts easy, warm starts are the trouble areas, not to mention the fuel in the oil. 53 PSI is low still. I think the key here is it starts when jumped. Take a fuel pressure reading when being jumped or with a known good battery.
Old Oct 2, 2012 | 12:04 PM
50lb_cat's Avatar
53 is not acceptable. The accepted range is 60 to 65 and must hold for 10 minutes without going below 55. And you don't have to open the plenum to look at the FPR. Just look down the throttle body with a flashlight. As stated earlier, try just changing the fuel filter. Your leakdown isn't very much, I would be leaning more to the pump since your prime number is so low. Check out the diy section to see how to modify a gauge to dead head the pump to rule it out.
Old Oct 3, 2012 | 06:50 AM
new fuel filter about a month old.
also would a 3rd party pump be worth it?
the one i am looking at is about 50 bucks. yea i know it is cheap but who has 329 for a acdelco pump now days. i owe less than that on it.
also is this enough cold cranking amps 650
Old Oct 3, 2012 | 08:53 AM
rexmburns's Avatar
Super Moderator
Don't buy the cheap pump spend the money or you will be doing this again very very soon!!
Old Oct 3, 2012 | 03:30 PM
i was going to just the pump for testing.
also it very weird that it will start and run wean jumped.
the things i can think of are
1. dragging fuel pump
2. dragging starter
3. battery not holding a charge over night but passes battery test wean charged.
igs4dragon8
Feb 12, 2013 11:30 AM
Bill Gillin
Dec 23, 2012 04:56 PM
davevictorine
Oct 10, 2011 08:26 AM
an240172
Nov 18, 2009 09:32 AM
alan98296
May 8, 2007 01:06 PM
