01 blazer no heat, coolant leak
Old Feb 9, 2010 | 04:40 PM
bofus86's Avatar
bofus86 is on a distinguished road
Default 01 blazer no heat, coolant leak
i have a 2001 blazer. i noticed it was overheating and i could smell coolant and saw i had a fairly decent leak toward the back of the engine. although my temp gauge was reading over half there was not hot air blowing from my defrost. when i refilled my coolant the temp went down and the heater blew hot air for a lil while then it stopped and overheated again. please help!
Old Feb 9, 2010 | 05:03 PM
If you have a leak, you will want to get it fixed.
As far as why it overheated again, you likely didn't get all of the air out of the system. These trucks can be pretty stubborn when it comes to releasing all of the air from a cooling system. Having a leak doesn't help things either.
Until you get the leak fixed, I would recommend you keep a close eye on both the coolant level in the radiator and the engine oil condition.
Old Feb 9, 2010 | 07:16 PM
terry s's Avatar
terry s is on a distinguished road
Low coolant level will resuly in overheating and lack of heat. If the leak is at the rear of the engine check the corners of the intake manifold for a leak.
Old Feb 9, 2010 | 09:00 PM
brians1bad72's Avatar
brians1bad72 is an unknown quantity at this point
Yep, it is probably you intake gaskets. I have a 2001 also and will be replacing mine this weekend common problem with these 4.3 engines. The dex-cool anti-freeze is the culprit, they eat away at the intake gaskets. Get the fel-pro revised intake gasket set, this will solve the problem. Part number is MS 98002 T.
Old Feb 9, 2010 | 09:07 PM
Couldn't be further from the real truth that GM chose the wrong gasket frame material for the job. The same thing can and does happen with regular green antifreeze. But we have an entire thread dedicated to that topic.
That is the best gasket for the job!
Old Feb 10, 2010 | 08:26 AM
terry s's Avatar
X2
moisy1968
Jan 21, 2013 12:40 PM
AcerDeucerQ
Dec 3, 2012 06:29 AM
scottspeer
Oct 20, 2012 08:38 AM
Lodi Dodi
Nov 12, 2010 06:26 PM
TAZ454
Jan 28, 2008 10:11 AM
