01 blazer stuck in 4 hi
Old Jul 17, 2012 | 01:36 PM
thog472's Avatar
thog472 is an unknown quantity at this point
Default 01 blazer stuck in 4 hi
I have a 2001 blazer with the np8 accutor motor for the transfer case, some months ago when the weather was bad i tried to lock the 4x4 in, the 4 hi button flashed but would not ingage, after trying several time the 4 hi locked in, however when i tried to go back into 2hi i couldnt, i disconected the battery and and tapped on the accutor motor and reconected the battery, pushed the 2hi button and the transfer case shifted into 2hi which is where i left it until i got a replacement for the accutor motor.
When i replaced the accutor motor i have the same symptons as before.
the blazer is stuck in 4 hi,
When i push the selector button the tccm clicks
the light flashes, the actuator motor hums but remains in 4 hi, it doesnt matter which button i select the blazer remains in 4 hi.
when i remove the fuss for the 4 wheel drive located in the dash the blazer is in 2 hi.
looking for any help.
Old Aug 8, 2012 | 08:28 AM
oktain's Avatar
*Moving to 2nd Gen Blazer Tech*
Old Nov 10, 2012 | 12:40 PM
ludwigkicker's Avatar
ludwigkicker is on a distinguished road
I am having the same issues, did you ever figure out what was causing the problem and how to fix it??
Old Nov 14, 2012 | 10:23 PM
GMJim3687's Avatar
GMJim3687 is on a distinguished road
they have issues with the transfer case modules. also there is a vacuum actuator under the battery. sometimes the van lines rot out. but if your HVAC mode switch works. usually it will not lead to a vac leak with your actuator.
Old Jan 15, 2013 | 07:19 PM
blazerboys00's Avatar
blazerboys00 is on a distinguished road
I had that issue.. I turned the key on, put it in neutral.. held the 2hi button n put the fuse in n out in n out in n out and it finally worked.. still dont know whats up with it, but it worked
Old Jan 16, 2013 | 01:09 AM
step66's Avatar
When I had that issue in my 96,it was that junk dash switch with the foil contacts that fell apart every time I touched it with more pressure than a q-tip!
stingray74
Mar 5, 2015 08:27 PM
mr.vls
May 4, 2013 03:45 AM
Havensk
Jul 25, 2010 08:16 PM
twintrades123
Sep 11, 2006 12:26 AM
bcmaxx
May 8, 2006 06:59 PM
