01 rough idle at start but goes away....
Old Jul 2, 2012 | 12:18 AM
prosnowsk8er's Avatar
prosnowsk8er is on a distinguished road
Default 01 rough idle at start but goes away....
so my 01 has a rough idle, almost a miss when i first start it and if i go drive it around it will go away, and not come back untill i leave it and try starting it again once its cold,
i've maybe driven it 3 times in the past 6 months, did a fresh oil change(noticed a bit of sludge) ran some seafoam, changed again, still nothing...
any suggestions?
Old Jul 2, 2012 | 05:21 AM
Shaun Bogen's Avatar
Shaun Bogen is on a distinguished road
my 99 did the same thing check your throttle body right where the valve is to let air in. it could be built up with carbon so the valve is having a little trouble opening and closing. i cleaned it and the problem seemed to go away
Old Jul 2, 2012 | 09:07 AM
Burnout66's Avatar
Burnout66 is on a distinguished road
Try a new cap and rotor, it could be corroded or shorted out in the cap from not being run so much. I almost guarantee this is the problem
Old Jul 2, 2012 | 09:45 AM
thanks for the fast replys, I'm going to check out both of those this morning.
Would the cap/rotor start working fine tho after it warms up? thats what doesnt make sense to me,
Old Jul 2, 2012 | 01:43 PM
50lb_cat's Avatar
Hard starting and rough idle in damp conditions is a classic sign of a bad cap and rotor. If it has been really humid where you live that can do it.
Old Jul 2, 2012 | 01:49 PM
Burnout66's Avatar
Yes, I have seen it numerous times... the cap shorts itself out within the plastic causing a misfire that can barely be heard but does throw a code usually and cant be heard with the rpms high. replace them with ac/ delco parts ONLY if you have the cash to.
fletch125
Jun 10, 2014 12:59 PM
98blazin
Oct 22, 2011 04:05 PM
jmac219
Aug 27, 2011 03:42 PM
CrashPro993
Nov 8, 2007 04:32 PM
liblrogers
Jan 2, 2007 08:41 PM
