01 S10 v6.. A few things...
Old Dec 27, 2008 | 01:33 PM
not my chevy's Avatar
not my chevy is an unknown quantity at this point
Default 01 S10 v6.. A few things...
I posted this on a different site, but there isn't much action there. Maybe you guys can help.
My brother in-law took his truck in to have a leak checked out. They told him the following:
Oil cooler pipes on tranny leaking (non 4x4)$440
Lower intake mani (gasket?)leaking coolant+replacet-stat$500
Front+Rear shocks leaking $400
I told him not to have any of the work done because thats a lot of money, and mostly in labor. I build and tune Audi/VW cars and have all kinds of experience and tools. I'm just wondering if after I verify this diagnosis to be true, are there any relatedDIY articles floating around here mainly for the tranny cooler and intake mani? Are these normal issues with these engines at ~70k miles?
I didn't see anything in the DIY section other than some fault code definitions.\
Thanks.
Old Dec 27, 2008 | 04:28 PM
Default RE: 01 S10 v6.. A few things...
A good DIY article from D-tips has been posted quite a few times for the intake manifold gaskets.
4.3L Intake Manifold Gasket Replacement - DTips.com
As far as the transmission cooler lines, there is nothing special about them other than how they connect to the transmission. They clip into a special fitting that can be fun to deal with. I would recommend you find the area where the leak is, then cut the line and sleeve it with some rubber hose & hose clamps. Just make sure that the rubber hose is compatible with the temperature and transmission fluid.
travisrussell88
Oct 20, 2011 10:16 PM
scott_wheels
Jan 26, 2010 05:49 PM
82blazerchick
Apr 14, 2009 02:57 PM
sonicdrft
Dec 29, 2006 12:42 PM
95BlacerMississippi
Sep 11, 2006 04:21 AM
