02 Blazer Battery Not Charging
Old Apr 4, 2011 | 09:08 PM
35Rem's Avatar
35Rem is on a distinguished road
Default 02 Blazer Battery Not Charging
4 dr, 4.3 L, 2wd
Not sure. Alternator checks out good and so does battery. Both were installed in December (less than 5 months old).
Voltmeter sits about 9 volts while running. Sometimes it will go up to 12.5 volts, but not often. It's discharging.
What can it be???
Old Apr 5, 2011 | 06:27 AM
Pewter2002's Avatar
Pewter2002 is on a distinguished road
Red face
Start with the easy stuff first.
Are your battery cable ends bright & tight? Even a clean external connector can be corroded inside the insulation. Closely check the connection at the negative battery to engine/chassis area. Remove, thoroughly clean and replace. The diode pack inside the new alternator could be bad, giving intermittent readings even though it tested OK. If you can, try a different alternator. Is it possible to have your belt routed backwards? Just a wild thought to throw out there. Double check the connector at the alternator to make sure the pins/plugs are all making contact and are not bent. Use a little di-electric grease at connectors. And double check the battery. Is it sealed or can you check the electrolite level inside? Confirm charge status with a hand-held voltage meter. Hope this helps.
Curt8153
Jan 2, 2014 06:48 AM
uhlhazard
Dec 13, 2011 06:48 AM
mlkk993
Jul 18, 2010 02:39 PM
odfareal
Nitrous, Super Chargers, & Turbos
Oct 26, 2009 01:36 PM
wetdog
Dec 15, 2008 05:39 AM
