02 Blazer stalls at stoplight
Old Mar 17, 2014 | 11:34 AM
friendscallmeslim's Avatar
friendscallmeslim is on a distinguished road
Default 02 Blazer stalls at stoplight
Blazer was running a random misfire code, changed distributor cap, rotor, coil, plugs & wires.. and for an extra measure changed the fuel pump. SES went off so I thought I got it! Drove good- better than I can ever remember, yesterday it was raining; went to town and at my very first stop it stalled. Heartbreaking! Continued to die at every stop. Did good on the way home when rain had slowed down. Any any any suggestions??
Old Mar 17, 2014 | 11:49 AM
spittybays
Guest
Posts: n/a
Does your truck have an EGR valve?
Old Mar 17, 2014 | 01:10 PM
Not sure what that even is, or if mine has it. It's an 02 ls 4x4.
Old Mar 17, 2014 | 04:34 PM
Gonna clean the throttle body & I'll let ya know how that goes.
Old Mar 17, 2014 | 08:00 PM
vegie_2's Avatar
vegie_2 is on a distinguished road
Did you use A/C Delco cap and rotor? It makes a difference
Old Mar 17, 2014 | 10:14 PM
Don't believe I did.
Old Mar 18, 2014 | 07:29 AM
LannyL81's Avatar
The '02 does not have an EGR valve....at least mine does not anyways.
Did the distributor cap hold down screws strip-out?
Did you put dielectric grease on the distributor cap contacts?
This engine really only likes AC Delco ignition parts; probably going to have to change the cap and rotor.
Also check the distributor shaft for excess movement. Good news is that replacement aluminum distributors are available for only about $50 and seem to work just fine. They do not come with AC Delco cap and rotor though, so need to change them.
Old Mar 18, 2014 | 07:59 AM
I noticed when I was putting the new wires on (time reasons had to put plugs & wires on a couple days after replacing cap & rotor) that the distributor cap was loose, I shook my head at myself for not doing my job right and tightened it down. Sure enough it's loose again. It has no wiggle once the cap is tight. My brother in law suggested cap problems because of acting up in rain but I knew I had changed it. I'll go for AC Delco and figure out a way to keep er on there. Should I or shouldn't I get the dielectric grease? I didn't but will if suggested. other suggestions before? I really appreciate your help.
Old Mar 18, 2014 | 12:22 PM
jpimp's Avatar
jpimp is on a distinguished road
yessir as stated above....use dielectric grease on ignition parts.
sparkie624
Aug 12, 2011 11:31 AM
Pewter2002
Aug 3, 2011 06:01 PM
JOEYSBLAZERS8902
Nov 16, 2007 09:53 AM
richard5294589
Dec 23, 2006 01:03 AM
see119
Aug 30, 2005 02:00 PM
