02 no start I'm torn
Old Dec 28, 2012 | 02:21 PM
jimhens82's Avatar
jimhens82 is on a distinguished road
Default 02 no start I'm torn
Ive verified that I get 60 keyed up I pulled the upper intake and found it washed so I replaced the regulator put it back together it fired right up, I did pull the spider and cleaned it off gently... I go out next day and its just cranking!!! It's gotta be in the spider, but could also be the check valve in the JUNK AIRTEX last year... Any suggestions ?? Thanks
Old Dec 28, 2012 | 03:40 PM
Ignition ON, engine OFF, fuel pump will run for ~2 seconds and shut off. Fuel pressure must be 60psi to 66psi while the pump is running. After the pump shuts off, pressure must remain above 55psi for at least 10 minutes. If it fails either or both parts of this test, further testing is required to pinpoint the problem. Post your results.
Old Dec 31, 2012 | 08:20 AM
jimhens82's Avatar
soon as i hook the pressure gauge up, i get 55 and it drops very fast, i ordered a new pump and spider assembly ughhh
Old Dec 31, 2012 | 08:42 AM
Probably the check valve in the Airtex pump is leaking, (VERY common). Provided there are no external fuel leaks, those parts should take care of the problem. Most manufacturers do an acceptable job with the injector assembly, the fuel pump is a different story... use AC Delco or Delphi only.
88 rusty but trusty
Jun 30, 2010 05:40 PM
CheapBeer
May 26, 2010 08:11 PM
dunontme
Sep 9, 2009 01:29 AM
WhiteTie BlackJacket
Aug 24, 2007 07:06 AM
WisdomRacing
Jul 17, 2007 02:57 PM
