04 AC Low Pressure Valve Replace, Add AC Oil on recharge?
Old Mar 30, 2019 | 08:58 AM
Drauka99's Avatar
Drauka99 is on a distinguished road
Default 04 AC Low Pressure Valve Replace, Add AC Oil on recharge?
Going to be replacing the leaking service valve on the low side port soon. Going to vacuum the system. Do I need to add oil as well as the R134?
Old Mar 30, 2019 | 09:05 AM
You should only add oil if you are replacing a major component that would hold a considerable amount of oil (compressor, condenser, evaporator, or lines). If the system has already leaked down or you have had it evacuated and are only replacing the valve, you should not need to add any oil.
Old Mar 30, 2019 | 09:07 AM
Drauka99's Avatar
After posting the related threads seem to have my answer. Which is no.
Next question. Compressor has a little rattle when running. Would a little oil help that or is it probably in the clutch.
Old Mar 30, 2019 | 01:34 PM
It is possibly the clutch. Should be easy enough to check by removing the belt and turning the pulley the belt rides on by hand. Any grittiness or play and the bearing is on its way out.
christine_208
15
Jun 8, 2018 02:17 AM
Jimmy_Blazer
Aug 23, 2015 02:30 PM
Jesster
May 29, 2014 02:38 PM
c6159b
Oct 11, 2011 03:30 PM
Big_Al
Sep 26, 2010 11:09 AM
