How much oil and freon in 1996 blazer
Old Oct 11, 2011 | 01:22 PM
c6159b's Avatar
c6159b is on a distinguished road
Default How much oil and freon in 1996 blazer
I'm replacing the compressor on my 1996 2wd blazer does anyone know how much oil and freon it takes to refill. I can't find the sticker that tells you this I thing it was lost when the plastic crumbled and fell apart. The new compressor has oil in it will this be enough or do I need to add more?
Old Oct 11, 2011 | 01:47 PM
pettyfog's Avatar
Dang I hate answering these.. I will just assume you have researched this thoroughly and are doing it right. You didnt explain why you're replacing the Comp so I assume the clutch pulley bearing failed and the snout was ruined.
34 oz, max, of 134a.
oil.. normally you rotate and drain the old comp and measure that but if yours already has oil, then add no more than 1 oz additional. That's to make up for what was in the old accumulator which you just replaced.
Old Oct 11, 2011 | 02:24 PM
c6159b's Avatar
I am replacing the compressor because the seal in the middle is leaking this seems to be a common problem with this model. I will be replacing the drier and will add 1oz. of oil for that. I don't know how many ozs. of oil are in new compressor so I will empty old comp. and put the same amount back in new comp. Thanks for your help I needed that info on amount of freon.
Old Oct 11, 2011 | 02:49 PM
pettyfog's Avatar
Sorry if I wasnt clear.
If you empty the old, also empty the new.
New may / should have more. Add enough to make up the difference, if any. Dont take out if new has more.
Then only 1/2 to 1 oz for the accum.
Since you didnt have to flush system, I'd go with 1/2 oz for the accum
Hope that's clearer.
- I dunno why they do a full fill in replacement compressors without a note saying that, or how to install proper amount. Last one I did from a box had detail instructions. They did a fill and drain at factory, noted the comp did not contain oil, then inst on how to set proper level.
Old Oct 11, 2011 | 03:30 PM
c6159b's Avatar
I guess I didn't type that right.lol I am going to empty both and put back the amount the old comp. had. I am assuming I lost some oil were it's leaking and will add an 0z. or 2 for that. It's been leaking for years and I've been adding freon. Thanks again for your help.
mr.vls
Aug 24, 2013 02:50 PM
hypertek
Jun 16, 2011 10:46 PM
dbldown768
Jun 29, 2010 12:59 PM
pmezo
Jan 31, 2009 07:13 PM
blazerscooby
Jul 2, 2006 09:11 PM
