05 chevy blazer
Old Jul 28, 2022 | 07:05 PM
Jacksmith's Avatar
Jacksmith is on a distinguished road
Default 05 chevy blazer
Keep popping codes 452 and 449, Replaced the charcol canister and fuel tank pressure sensor. Erased the codes but then they come back, noticed the spring loaded trap door in fuel filler opening is missing. Could that be it?
Old Jul 28, 2022 | 11:16 PM
GeorgeLG's Avatar
When you replaced the fuel tanl pressure sensor, did you test the 5v reference circuit?
Why did you replace the charcoal canister, was it leaking or plugged?
Have you done any work on the vent solenoid?
'Have you checked the system for leaks?
George
Old Aug 2, 2022 | 02:17 AM
Jacksmith's Avatar
Also there is a spring loaded gate inside of the fuel filler intake that is jammed open. Would that have anything to do with the codes popping?
Old Aug 2, 2022 | 08:01 AM
GeorgeLG's Avatar
No that thin metal spring loaded door would not cause this because that filler neck opening should be getting properly sealed by the gas cap (a common source of evap codes).
When you replaced the fuel tank pressure sensor did you test the reference voltages and wiring?
why did you replace the charcoal canister, what problem were you trying to address?
Have you addressed any other part of the evap system (vent or purge solenoid, pipes, leaks, gas cap, …)?
when a sensor reports an out of bounds condition: the sensor may have failed, the voltages (if applicable) to the sensor may be faulty, the signal wiring may be faulty, the engine computer may be failing or the reported level may be accurate indicating a problem elsewhere.
George
Jacksmith
Jul 19, 2022 11:38 AM
Terry Ulrich
Mar 17, 2017 02:24 PM
achaps81
Apr 3, 2015 07:53 PM
TallHoe
Sep 27, 2011 12:26 PM
blazinDJ420
Jun 18, 2010 10:21 AM
