100k service / tuneup expensive?
Old Apr 2, 2008 | 12:04 PM
Ronald's Avatar
Ronald is an unknown quantity at this point
Default 100k service / tuneup expensive?
Hi, I'm new to the forum and to Blazers.
A friend of mine asked me if I could do the 100K service on his 2001 Blazer (V6) because he has heard that tune up is very expensive if you have it done by the dealer.
What's needed for that service besides replacing the fluids?
(motor oil, gearbox oil, flush brake circuit, coolant, oil filter, fuel filter, airfilter is what I'm thinking of)
I know how to work on cars, but don't have any experience on blazers, so if you could tell me some more about this tune up, it's appriciated
Old Apr 2, 2008 | 03:03 PM
Smoked's Avatar
Smoked is an unknown quantity at this point
Default RE: 100k service / tuneup expensive?
ORIGINAL: Ronald
Hey Ronald. Opinions on what to do and when with any car is somewhat subjective. The manufacturer has their recommendations and many other people with varying degrees of experience have theirs. I'm only mildly experienced, so i'll leave the opinions to those that have more but the list you've compiled is very comprehensive...missing only ignition compenents such as plugs and wires.
The rest can never hurt to do and will certainly prolong the vehicles life...but may benefit from inspection before simply changing them.
Good luck!
Old Apr 2, 2008 | 04:34 PM
WolfPack's Avatar
You're also going to want to do the axles. Taking off the differential covers, cleaning all the parts with brake cleaner, and refill. You might want to consider switch to synthetic! Also consider synthetic power steering fluid.
The biggest thing with the 100k mile service is that 100k is the service life of alot of parts. You might not need to replace them, but definitely a comprehensive inspection. Check your belt (probably just go ahead and replace it), PCV valve, EGR valve could be cleaned, inspect the brakes, rotors/calipers/pads, replace distributor cap and rotor, and you also will probably want to an induction cleaning (seafoam via vaccuum hose) to get 100k miles worth of carbon buildup out of the intake and engine.
I'm in the process of doing my 100k mile stuff, but doing it over the course of a few weekends. I priced out a whole list, total it'll be about $200, but mine includes new front rotors (mine are warped), and I don't have a coolant change because I just did one at 90k.
Old Apr 2, 2008 | 05:24 PM
I would recommend a seafoam treatment. You can dribble it down through the throttle body, but remember to disconnect the MAF sensor first. Once you have done that, change the plugs, wires, cap and rotor (plugs only if the other stuff has been replaced recently) as well as do a motor oil/filter change.
As already mentioned, flush/change the engine coolant, change the thermostat, change the rad cap, change the diff fluids, transfer case fluid, transmission fluid/filter (install a drain plug so next time you only have to drain the pan), inspect the tires, rims, brake pads/rotors, brake flex lines for cracks, flush the brake fluid, flush the power steering fluid, inspect the steering components, ball joints, sway bar end links, shocks and grease the front end.
Rumblur
Nov 13, 2013 03:00 AM
matt92
Nov 21, 2012 10:41 AM
matt92
Nov 15, 2012 03:34 PM
Wexinlo
26
Apr 9, 2011 03:37 AM
jmaynard
Aug 26, 2010 07:25 PM
