1995 blazer 4.3 vortec Torsion Bar Mount Replacement
Old Nov 24, 2018 | 11:03 PM
Matthew Anglin's Avatar
Matthew Anglin is on a distinguished road
Default 1995 blazer 4.3 vortec Torsion Bar Mount Replacement
Does anyone have a guide or video showing how to replace the torsion bar mounts? I hit a big pot hole and my driver side torsion bar mount bolt on the frame got bent up and now the torsion bar clunks going over bumps
Old Nov 25, 2018 | 09:36 AM
I remember watching a video on YouTube of someone changing their torsion keys. They removed the torsion bar mount to change them. Maybe check there. I'll see if I can find it and post it.
Old Nov 25, 2018 | 07:11 PM
2001ZR2's Avatar
I have just replaced these as part of a Lower Control Arm Bushing replacement. The Torsion Bars need to be unloaded with a special tool then the T-Bolts need to be removed while counting the turns of the ratchet because to reestablish ride height you'll need to be put them back.
It is a high pucker factor job and you must respect the Torsion Bars because if you don't unload them they will push the cross member down with force.
Please be absolutely sure you know what you're doing and what the risks are as I would expect this to be an easy job for a shop.
If I over explained this I apologize but I would rather warn you than leave out something
Old Nov 30, 2018 | 07:05 PM
LannyL81's Avatar
The torsion rod tool is available on ebay....not very expensive...just do a search for it.
Brandon Koharchik
Jan 20, 2018 06:38 AM
gatorboy44
20
Mar 21, 2012 01:24 PM
tony991
Jun 2, 2010 03:57 PM
slickwilly
Oct 29, 2008 10:26 PM
sasquatchfound
Suspension Tech
Aug 24, 2008 02:48 PM
