1995 Blazer Fuel Lines Leak
Old May 30, 2012 | 12:51 AM
jay1992's Avatar
jay1992 is on a distinguished road
Default 1995 Blazer Fuel Lines Leak
My blazer had fuel spraying from one of the lines under the back end. I was told I had to replace the whole gas tank or fuel pump to get the lines, but my question was, could I just buy the lines or maybe repair them by getting some rubber hose and hose clamps and cutting out the bad section of the line and replacing it with the rubber hose and clamps? Or do I have to get the whole unit? It was pretty rusty which I believe caused the small pinhole causing it to spray fuel out... I can get pictures if needed. I was thinking about going in the morning and getting the rubber hose and clamps if I can do that and try experiencing a with it myself. I'd appreciate any advice. Thanks.
Old May 30, 2012 | 01:43 PM
Fuel injection rated rubber line will work as a temporary patch job. If you want to do the job properly and safely, cut out the rusty line and use compression fittings and steel line. The pressure line is 3/8" & the return line is 5/16". If you need to go more than a couple of feet or so, it's cheaper to use compression fittings anyway.
Old May 30, 2012 | 07:37 PM
jay1992's Avatar
I tried cutting out the bad section of the lines and replacing it with some rubber fuel line and clamping it down, but then I noticed that I have fuel spraying toward the base of the 2 lines on the top that go down into the fuel pump/sending unit. it's just a small pinhole so I was thinking make putting some JB Weld in the area around where it's leaking at, or should I just replace the whole fuel pump/sending unit?
Old May 30, 2012 | 08:40 PM
abig84's Avatar
i dont think jb weld will hold with it being rotted and that much pressure. if its rotted on the actual sending unit then yeah looks like youre gonna have to buy a new sending unit.
Old May 30, 2012 | 08:58 PM
scottl1346's Avatar
scottl1346 is on a distinguished road
you cant just cut the line and put a rubber hose over it you have to cut the metal fuel line and use a double flair tool (rent one at autozone) to put the flair on the end of the line then slide your rubber line over it and clamp it thats how my truck is done and its been holding up for about a year
Big Eazy
Apr 27, 2013 12:48 PM
skid9832004
Jun 5, 2011 01:38 PM
dj00140
Apr 13, 2011 10:48 PM
