1995 Blazer Idle problems
Old Jul 4, 2011 | 10:00 AM
ron36535's Avatar
ron36535 is an unknown quantity at this point
Default 1995 Blazer Idle problems
Parts of my question has been ask in other post, but I'm still having issue's. My blazer does not idle good. going down the road everything is fine. I have already replaced my IAC valve,but it did not help. what other sensors or idea's does anyone else have. I have also aready looked at the EGR valve, that is good. any pic's of under the hood with sensors I could look at ?
Old Jul 4, 2011 | 04:19 PM
bugs825's Avatar
bugs825 is on a distinguished road
You could check the Nut Kit. Its the supply and return lines that go to the CPI spider under the plenum. A simple fuel pressure check after the key is off for a couple minutes should do the trick. That was what my rough idle problem was, well, as well as plugs.
Nathan
Old Jul 4, 2011 | 06:35 PM
Chevy33's Avatar
Chevy33 is on a distinguished road
Default Just a thought
Perhaps the distributor is gone. It will run but not well if the spark advance components are toast.
cobi712
Oct 1, 2009 01:05 AM
adavis12
Jan 14, 2009 12:29 PM
addai29
Nov 11, 2008 10:47 AM
Blazer4U
Aug 18, 2008 07:23 PM
djkrash
Jul 29, 2008 09:15 PM
