1995 Blazer temp gauge not working
Ok so my temp gauge goes all the way hot when the one wire connector is plugged up to the sensor and I already replaced this sensor and when disconnected the temp gauge goes all the way cold and I seen somewhere on here you can ground that wire and the temp gauge should go all the way hot when you ground it but it does nothing it stays cold so if my temp gauge is broken why would the temp gauge go all the way hot with the sensor plugged in
pinstriped blazer
Jul 13, 2010 12:33 AM
Imperator
Apr 7, 2010 05:05 PM
