Temp gauge not working
Old Jun 11, 2010 | 11:27 PM
camino88's Avatar
camino88 is on a distinguished road
Default Temp gauge not working
Ok I recently taken the whole motor apart to replace a burnt valve but now that i got that fixed and put it back together, the temp gauge does not show up anything, anyone care to tell me what i might have missed to hook up putting it back together or where that censor is that controls that so i could check it. Also if you consider this double posting let me know I am aware I have been doing that unknowingly, but i thought this deserved its own thread because it is a separate issue.
Old Jun 12, 2010 | 12:22 AM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
the coolant temp sensor is on the driver side cylinder head towards the rear, it should be a one wire sensor, take the wire and ground it, the gauge should go to max temp IF the wiring and gauge are good, if that happens then the sensor is bad, if not then you have a wiring issue.
zakm0n
Jan 9, 2011 07:31 PM
DaddyCop03
May 11, 2008 09:07 PM
Mulisha
Mar 24, 2008 09:14 PM
haught62
May 1, 2006 01:37 PM
