1995 Blazer Turn Signal Help
Old Aug 9, 2012 | 05:55 PM
SpeedBlazer's Avatar
SpeedBlazer is on a distinguished road
Default 1995 Blazer Turn Signal Help
Ok, so here's my problem. My turn signals on my Chevy 1995 blazer (4 x 2) do not work, nor do they flash. However, my hazard lights still work and flash correctly.
Here's what I did:
I checked my fuses, and all seemed to be well.
Next I checked my relay access panel inside the glove compartment, and replaced the two unit inside said panel. NOW for a day, my signals and flashers worked again, but while I was driving they slowly stopped working.
My question:
I do not know what my next step should be, as I only have basic car/mechanical knowledge. Could this be a wiring issue, or could it have something to do with multifunction stick, or should I just go ahead and take it into the shop, so I can save myself a headache?
Thanks in advance,
SpeedBlazer
Old Aug 9, 2012 | 11:48 PM
4x4blazerguy's Avatar
I'm not sure I follow you on this. Did you replace the Flasher? There are two flashers one for turn signals & one for 4 ways. On my 97 Blazer they were located behind the lighter area. I had to remove the lower dash panels to get to them. One the 98s up I believe they moved them behind the glove box.
SubbinBlazer
May 24, 2013 12:56 PM
tbuck23
Nov 26, 2011 02:21 PM
csboged
Aug 8, 2010 08:17 AM
ta3ff
Oct 14, 2009 05:07 PM
shaka1111
Feb 13, 2006 02:23 PM
