1995 W Block Cmfi Nut Kit
Ok everybody,a fuel spider is technically a fuel injector kit according to parts stores. My question is what part or part number is a nut kit as advance auto and auto zone being stupidified when I tell them I need to replace my nut kit. All help greatly appreciated!!!
Part Number would be best if you got it!!
Thank you!
Thank you!
Ok.. nut kit numbers helped a ton! Was able to purchase and obtain the same day.
Installed nut kit, installed fuel spider, turned key, checked for leaks, no problems! Installed upper plenum, connectors, vacuum lines, etc etc. Torqued down intake, etc etc.
Fired it up, and... misfire still here.
Pulled all plugs, set on block, checked each for spark from distributor. All are sparking perfectly when starter turned.
And I'm assuming all cylinders are getting fuel, due to new nut kit and spider.
So... what could still possibly be wrong?
grey95chevyboy
07-14-2014 09:50 PM
midnightmekanik
10-08-2009 08:32 PM
7mmremag
07-03-2009 10:40 PM
lil_blazin
05-10-2009 05:20 PM
