1996 blaze stalls when stoping
![Angry](https://blazerforum.com/forum/images/icons/icon8.gif)
ya i got a 1996 blazer 4.3 and in the morning it starts and dies 3 or 4 times then will run when u start driving it the brake and abs lights come on and it stallswhen slowing down it will start right back up it will do it for a bit but if u rev it up it will stop doing it untill u shut it off then it starts doing it again
![Icon No](https://blazerforum.com/forum/images/smilies/icon_no.gif)
What have you done to try to correct this? Is the check engine light on? Have you had the codes read? If so, were there any present -- which ones specifically (Pxxxx)?
When was the last time that a tune up was done consisting of plugs, wires, cap, & rotor? Have you cleaned the throttle body and removed, cleaned, and reinstalled the IAC valve (on the driver side of the throttle body at the back)? Have you cleaned the EGR valve? How about the MAF sensor?
A look inside the Tech Article (DIY) section will help you with many of the general tune up items. The EGR Valve Cleaning thread will help.
If your light doesn't work, I would recommend you get it fixed. Having a malfunctioning CEL doesn't do anyone any good.
BuddyS
12-13-2014 11:18 AM
akblazer2000
06-19-2012 05:34 PM
05box
04-23-2008 07:25 PM
