1996 Blazer 4x4 problem
Old Nov 20, 2007 | 12:20 PM
megatrack's Avatar
megatrack is an unknown quantity at this point
Default 1996 Blazer 4x4 problem
Hi,
My 4x4 doesn't work. When I press on the switch I can hear it engaged but it doesnt work. Switcheswork fine from 2w to 4w and back, 4 low seems to engage( I can hear it).So to make a story shortall the switches work but the front wheels never engaged.
Can anyone help please
Thanks
AJ
Old Nov 20, 2007 | 12:23 PM
Default RE: 1996 Blazer 4x4 problem
First verify engine vacuum to the front axle engagement actuator located under the battery tray. If you have vacuum there, then I'd bet that the actuator has failed in some way (cracked diaphram, frozen cable, etc).
Old Nov 20, 2007 | 12:35 PM
megatrack's Avatar
HI,Thanks for helping,
So you are saying that even if I hear it engaged there can be a vacuum problem.
I will look at it right now.
I am in Vermont we had snow today....already...
Thanks
AJ
Old Nov 21, 2007 | 03:53 PM
megatrack's Avatar
HI, I checked the actuator today, It looks like it is working but when I put it in 4HI I can still push the cablein by hand about 1/4 in the actuator. So I am wondering if the actuator is not strong enough to pull on the cable completely. Is it possible?
How to tell if the 4x4 work other than trying it in snow?
Thanks
AJ
txc008
Mar 1, 2015 12:51 PM
sarahj
Mar 3, 2010 12:16 AM
hevi99
Jan 7, 2010 03:45 PM
chuck757co
Mar 18, 2009 03:26 PM
tpdavis
Aug 10, 2006 03:16 PM
