1996 Ignition Coil
Old Oct 30, 2008 | 01:04 PM
chevblazer02's Avatar
chevblazer02 is an unknown quantity at this point
Default 1996 Ignition Coil
Well my grandmother has a 1996 AWD blazer, and it wasn't running correct monday, so I popped the hood and noticed sparks jumping from the ignition coil when we hit the gas. I'm assuming this means it is bad and needs to be replaced, it now will not start but you can still see some sparks from the ignition coil. How hard is it to replace this and what kind of tools do you need? If it was nice out I would just try to do it, but its currently in the 30's and I dont have a garage to work in currently, so the shorter the time it takes the better. Any help is appreciated. Thanks Jon
Old Oct 30, 2008 | 01:07 PM
Default RE: 1996 Ignition Coil
It is quite easy. If you remove the whole bracket (2- 10mm fasteners), you will remove the whole ICM/Coil assembly. You can then take it someplace warm to swap the coil out.
Old Oct 30, 2008 | 01:11 PM
Alright, Sounds simple enough......Thanks for the quick reply
blainenbecky
Mar 9, 2013 10:38 PM
gohan69
Engine & Internal
18
Mar 22, 2011 08:12 AM
Lancealot
Feb 22, 2011 07:34 AM
skoot61
Feb 19, 2008 11:20 AM
xdieselx3032
Engine & Internal
Aug 14, 2007 10:59 PM
