1997 blazer
Old Nov 29, 2006 | 11:41 PM
sweetbriar's Avatar
sweetbriar is an unknown quantity at this point
Default 1997 blazer
After about 20 minutes my headlights turn off and only my day light running lights are on. After afew seconds they comeback on. Any ideas on what is causing this?
Old Nov 30, 2006 | 01:25 AM
Chevy Lover's Avatar
Default RE: 1997 blazer
Welcome to the forum.
If you post your questions in the General Technical Help section, there's a chance more people will reply.
I'd think that maybe you have a weak headlight relay.
Old Nov 30, 2006 | 10:13 AM
*Post Moved*
Old Nov 30, 2006 | 12:29 PM
DCFluX's Avatar
DCFluX is an unknown quantity at this point
Do you have Automatic Head Lights (AHL) as well? If so I would assume it is a bad AHL sensor. Does it do this with the headlight switch in the full on position?
Old Dec 1, 2006 | 03:52 AM
Any luck?
Let us know what you find.
Old Dec 21, 2006 | 12:37 AM
mrspeedy69's Avatar
mrspeedy69 is an unknown quantity at this point
Check your headlight switch, maybe it has a bad connection.
Old Dec 21, 2006 | 10:02 AM
What is the outdoor lighting conditions when this happens? It is possible that you are right on the threshold of when the lights should be off/DRLs on and vise versa.
Old Dec 21, 2006 | 10:01 PM
Rammer's Avatar
Rammer is an unknown quantity at this point
Sounds like a short is tripping the circuit breaker. Also, Check the headlamp switch.
hlaverty06
Mar 23, 2014 09:25 AM
jbw23
Sep 5, 2012 08:56 PM
vtlew
Jun 23, 2006 09:13 PM
polcat1998
Mar 1, 2006 06:05 PM
reggie4828
Engine & Internal
Jan 6, 2005 10:58 PM
