1997 Blazer not starting after new parts
Old Nov 20, 2024 | 09:35 PM
Originally Posted by BlazerDog97S10
Okay this thread is done, I got him running. The only thing I changed was adding another spacer to the crank position sensor. Wtf.
He's alive!!!
Congrats!
hmm a spacer for the CPS. I wasn't aware that was a thing!
Old Nov 20, 2024 | 09:43 PM
GeorgeLG's Avatar
Was there evidence of gear impact to the crank sensor before the extra shim?
George
Old Nov 21, 2024 | 02:20 AM
BlazerDog97S10's Avatar
George
Yes the one I replaced the old one with was damaged just from trying to crank it over. The second replacement sensor I got spacers for. I tried it with one spacer first, and when no start I figure why not put the other spacer on, and he fired right up. Appears to have been the issue all along.
Now the replacement gauge cluster doesn't read
rpm and vehicle speed. And only registers oil pressure when I press on the gas pedal. Oh well, yet another thing I have to fix.
Old Nov 21, 2024 | 07:03 AM
GeorgeLG's Avatar
You will need to perform a relearn on that new crank sensor. Also, that low compression on C4 May give you some trouble at some point. Keep both of these in mind if you have misfire issues down the road.
George
Old Nov 21, 2024 | 10:22 PM
George
Thanks, I was planning on taking him somewhere that does relearns and maybe have them check other things.
Chevychase2001
Oct 7, 2024 04:26 PM
Blaz_r
Feb 16, 2024 09:21 PM
Nativewayz
Jul 30, 2017 05:09 PM
BlazerBuilder
Mar 23, 2014 08:40 PM
cuzmo21
Sep 5, 2009 09:58 AM
