1997 blazer transmission is suealing and wont go in reverse what is wrong?and what c
Old Apr 20, 2011 | 11:56 AM
199634's Avatar
199634 is on a distinguished road
Default 1997 blazer transmission is suealing and wont go in reverse what is wrong?and what c
1997 blazer the transmission is making a whining noise it goes into to drive but does not go into reverse what could be the problem?
Old Apr 20, 2011 | 12:13 PM
To quote another post I made recently:
Originally Posted by swartlkk
Sounds like the infamous broken sun shell. If your fluid level (checked with the engine running and the truck on a flat level surface) checks out ok, you are likely in for a tear down if not an all out rebuild.
I'm betting you don't have 2nd or 4th gears either. Just 1st & 3rd.
Old Apr 20, 2011 | 12:54 PM
199634's Avatar
I have all other gears except reverse
Old Apr 20, 2011 | 01:12 PM
You have physically driven it and confirmed that all 4 forward gears engage? If so, then this pretty much sums it up :
Slow, slipping or no reverse: “lo-reverse” clutches are worn out, fluid leak in the reverse apply circuit, or broken sunshell. It is possible to remedy a fluid problem by removing the checkball from its cage in the case in the rear of the trans may help (must remove valvebody), or adding a high-viscosity additive such as Lucas Transmission additive or other seal restorer product.
Old Apr 20, 2011 | 02:09 PM
199634's Avatar
Thank you all.
upmaine
Jul 14, 2012 01:03 PM
waviaerith
Apr 26, 2011 02:55 PM
kennycraze
Apr 19, 2011 06:25 AM
Albundy
Jan 31, 2011 06:49 AM
rknight
Dec 24, 2010 04:46 PM
