1997 hard start
Old Jun 8, 2013 | 10:04 AM
dawgbyte01's Avatar
dawgbyte01 is on a distinguished road
Default 1997 hard start
1997 4 door 262,000. Replaced FP 6 months ago w ac/delco, new filter. When key on no fuel pump prime. When turn key off 2 sec prime. Relaced relay no change. Prime it it runs fine with 58-64 lbs. when cranking 0psi but when primed 58-64psi. leakdown drops to 56 when shut off. holds at 56 for 15 minutes. Also going at speed it quit then started back on its own. did this once. this is when start issues began. maybe ignition switch?
Old Jun 8, 2013 | 11:39 AM
dawgbyte01's Avatar
update. when it cut out on me I replaced relay. this is when priming issue started. if off more than 20 minutes must prime to start with new relay in. Switched back to old relay and it starts fine but wants to stall. new relay,prime, no stall. perplexing.
Old Jun 8, 2013 | 06:58 PM
When the ignition is in the RUN position, (engine off) the pump should run for ~2 seconds and shut off. When the ignition is in the CRANK position the pump should run continuously. Those are two separate circuits from the ignition switch. The ignition switch on 1997 is unique to that year and it's very common to have problems like you're describing. In the underhood fuse panel, locate the CRANK fuse. Both terminals on the top of the fuse should show battery voltage when the starter is engaged. If not, the ignition switch is the most likely cause. https://blazerforum.com/forum/articl...-switch-33465/
Old Jun 9, 2013 | 09:20 AM
Tempest73's Avatar
Tempest73 is on a distinguished road
I am having the same trouble, thanks for the post. Got lots more reading todo
Old Jun 10, 2013 | 07:47 PM
dawgbyte01's Avatar
Thanks Hook. I have been reading up in this forum and it sounds like the switch is one of those things that make you "huh"
Old Jul 18, 2013 | 05:31 PM
dawgbyte01's Avatar
heres the rundown, new ignition switch, fuel pump, filter, plug, map sensor, icm, coil, plugs, wires, dist. cap, crank sensor, relay, all from the dealership. fuel pressure at 58psi at idle goes to 62 psi when shut off for 25 minutes. Must prime to start. once started runs great. One thing that is different is that new fuel pump does not shut off after 2 seconds when key is on but does shut off after 2 seconds when key is turned off. Pump also runs on accy. driving me crazy. any ideas
Kevin Gore
Dec 13, 2013 09:35 PM
todd083
Apr 14, 2012 10:59 PM
dubaholic2
May 24, 2011 12:44 PM
ejxjohnson
Sep 10, 2010 08:21 PM
recknmb
Jun 19, 2007 08:56 PM
