1999 zr2 hard to start, now no start
Old May 22, 2011 | 07:18 PM
dubaholic2's Avatar
dubaholic2 is on a distinguished road
Default 1999 zr2 hard to start, now no start
ive read a bunch of threads on here on the passlock system and im leaning toward that being the problem, but im not 100% so i figured i would ask some opinions. please read the story and post your opinion. i bought this 1999 zr2 a couple months ago at a decent deal because it had some issues, one of which was that it was hard to start. it would turn over for about 5 seconds or so and then start (seemed to help if you tapped the gas), but it started and it had a rough idle. drove it like that for about 500 miles or so and then it got to where it wouldnt always start. now it starts and immediately dies and then i get nothing. fuel pump doesnt run when the key is turned on. 0 fuel pressure. i was thinking it was the fuel pump, but the way it worked off and on tends to lead me away from that. please give me any and all opinions and/or things to test. thanks in advance for the info, ian
Old May 24, 2011 | 11:41 AM
I'm not sure if you have seen either of these threads, but they may be of some help:
Engine Cranks But Does Not Run
No-Start - Engine Cranks OK - Ignition System Diagnosis
It is also possible that the ignition switch is at fault (see the link in my signature). It can cause all sorts of whacky things to happen.
A problem with the Passlock system would not inhibit the fuel pump prime when the key is initially turned to the 'RUN' position.
Old May 24, 2011 | 12:44 PM
GunsOfNavarone's Avatar
GunsOfNavarone is on a distinguished road
Very common issues for your 99 ZR2 not starting or dying while driving include:
#1 Fuel pump- even if it is good should be updated to new stlye with better connectors, the pump will fail- just a matter of when
#2 Ignition switch- when the ignition switch starts to fail gives all the same symptoms of a failing fuel pump
#3 Crankshaft speed sensor
#4 distributor cap/ rotor
Good luck....
DCFluX
Aug 25, 2013 02:31 AM
Josh2012
Aug 16, 2012 01:44 PM
dubaholic2
Jun 18, 2011 11:58 AM
boaterdude83
Nov 3, 2008 11:09 AM
alan98296
May 8, 2007 01:06 PM
