1997 jimmy heating/hvac problems
I have a 98 gmc jimmy. It has the auto climate control. The problem I have is the air only comes from the vents and I only have hot nothing else. Any help would be appreciated. Is it the actuator, controller, vacuum line.
I had the same problem with my '01. If you look on the drivers side fender, there's a vac line running to a vac reservoir inside the fender. Make sure that line is connected. There's also a T-fitting with another line coming off of that one. Make sure that is connected also. Mine was broken at the T-fitting and I couldn't find the original line to reconnect it so I ran a new line.
question for blu s10...All of my vacuum lines are bad and I am replacing them...can you tell me how to access the reservoir inside the fender?
what do you mean by only coming out of the vents?
is it just your a/c that wont work?
rclatterbuck
02-08-2013 08:10 AM
reidzap
15
12-01-2010 03:23 AM
jojocarreno
07-01-2010 07:30 PM
Greed
12-02-2008 09:49 AM
Canadian88
01-19-2007 05:40 PM
