1997 LT Oil Leak
Old Mar 8, 2014 | 03:40 PM
userID-81055's Avatar
userID-81055 is on a distinguished road
Default 1997 LT Oil Leak
Okay so i've been a proud Blazer owner for a little over a year. It has always had a small oil leak, i've searched for the starting point but cannot find it. I've traced the oil to what I think is the Oil pan. Obviously this doesn't mean it is leaking from there. I saw a similar post to mine a while back but cannot find it for whatever reason. Any information helps!1997 LT Oil Leak-img_1645.jpg
Old Mar 8, 2014 | 08:35 PM
justaguywithtools's Avatar
justaguywithtools is on a distinguished road
from the pics it looks like the oil cooler lines could be the culprit. its a pressure leak so should be easy to spot with the vehicle running.
clean it off with brake and parts cleaner, or take it to the car wash bay. then run it and watch.
Old Mar 9, 2014 | 12:31 PM
07nhbpsi's Avatar
07nhbpsi is on a distinguished road
U got my vote for oil cooler lines!!!!!
Old Mar 9, 2014 | 01:20 PM
Thank you i'll take a look today. Would you say it is a relatively easy fix?
Old Mar 9, 2014 | 10:18 PM
07nhbpsi's Avatar
Yes easy, u will need a few extensions & some patience!!!! Lol u can wiggle the lines out if u jack the motor up...no need to remove the motor mount bolts I believe there is a dyi thread on this topic? Btw if u are gonna do it I suggest u buy the ac delco lines!!! I used the aftermarket & within 6 months had to use the warranty!!!! Try to find them either on rock auto or ebay motors!!!!
Old Mar 31, 2014 | 07:56 PM
er0ck273's Avatar
er0ck273 is on a distinguished road
yea that looks exactly like my leak, "mechanic" couldnt figure out where, but those damn rubber plugs are soaked too. gonna head out to harbor freight and get jack stands and see if thats where its coming from
my leaks was worse on an incline too, (how i park at work)
Old Mar 31, 2014 | 08:33 PM
hoebob69's Avatar
hoebob69 is on a distinguished road
If that's not it those models are bad about leaking near the rear main seal.
Old Apr 1, 2014 | 04:28 PM
LannyL81's Avatar
The 4.3 also is prone to leak oil from the plastic front cover.
if you have a 4wd, then there is ALOT of work involved in replacing either the rear main seal or the front cover.
Old Apr 1, 2014 | 06:11 PM
er0ck273's Avatar
i pray its neither of them.
i checked inside the bellhousing it was bone dry so does that eliminate the rear main seal?
Old Apr 3, 2014 | 04:14 PM
Default Update*
Found my leak finally, going to change my oil and replace the oil cooler lines. Thankfully it wasn't the rear main. Thanks for all your help!
