1998 Blazer blinker
Old Jan 10, 2007 | 01:52 PM
tonyca123's Avatar
tonyca123 is an unknown quantity at this point
Default 1998 Blazer blinker
the blinker sound goes on intermitently without turning the blinker signals on.
The blinker works fine left and right. I checked the bulbs no problems. The flashers work too.
I noticed when the blinker sound comes on by itself, when I step on the brake it stops the sound, however at times the sound will continue
any suggestions?
thanks
Old Jan 11, 2007 | 04:09 PM
vdog's Avatar
vdog is an unknown quantity at this point
Default RE: 1998 Blazer blinker
same problem as mine (i posted about ticking/gushing sounds)
Old Feb 17, 2008 | 12:11 AM
MT99BLAZERLS's Avatar
MT99BLAZERLS is an unknown quantity at this point
The ticking noise you are refering to is actually the turn signal/hazzard flasher. It is located below the glove box in the upperpassenger side floor area. The problem is actually NOT the flasher but, your multifunction switch is going bad on your steering column( also called your turn signal switch ). Replacement switches are avaliable for around 100 bucks. Hope this helps.
Old Feb 17, 2008 | 07:31 AM
Might want to try running a search as this topic has been discussed numerous times. You may not have to replace the entire switch as a replacement hazard switch is available and can be replaced quite easily.
blazintexas
May 1, 2012 06:01 AM
jscherbs
Mar 19, 2012 11:15 AM
Chenzo
Jul 11, 2011 03:47 PM
hunterman18
Apr 5, 2011 05:56 AM
hunterman18
Jan 7, 2011 08:00 AM
