1998 Blazer Heat A/C Problem
Old Apr 26, 2010 | 03:00 PM
jnardo58@hotmail.com's Avatar
jnardo58@hotmail.com is on a distinguished road
Default 1998 Blazer Heat A/C Problem
My a/c is charged and the compressor is running but all I get is heat. How do I know if it is the climate control temp switch or the door in the heater box? When I am driving you can feel the the air going from hot to cold.
Old Apr 26, 2010 | 03:01 PM
Do either of your A/C lines get cold?
Old Apr 26, 2010 | 03:38 PM
Both are cold
Old Apr 26, 2010 | 09:44 PM
65longroof's Avatar
65longroof is an unknown quantity at this point
It could be that the solinoid for the temp door is not moving.
Old Apr 27, 2010 | 06:20 AM
One A/C line should be cold, the other, quite hot... But if the air is not flowing through the A/C core in the HVAC housing, it may not get as hot because the system isn't working as hard.
I agree, it sounds like the temp door actuator (electronic actuator located on top of the HVAC housing behind the glove box - search for it) may be the likely culprit.
Old Apr 30, 2010 | 08:42 PM
Nizm0's Avatar
Nizm0 is on a distinguished road
Don't mean to threadjack but I just seen this after I posted my question. I'm having the same problem, but mine is staying on heat only, not switching back and forth, I looked under the dash and cant locate exactly which one you are talking about, any more info?
nevermind, did more searching
Last edited by swartlkk; Apr 30, 2010 at 09:33 PM. Reason: **Combining Consective Posts** - Please use the EDIT feature to add information to your post if another member has yet to reply.
Old Apr 30, 2010 | 10:50 PM
65longroof's Avatar
You may need to remove the dash to find it. This sounds worse then it is, the dash comes out of these things pretty easy. A few screws along the top, a couple on the bottom, drop the column and tilt the dash forward....not to bad of a job. You can then see all of the actuators.
tery
Jul 6, 2014 07:40 AM
schrack
Apr 5, 2014 09:15 AM
Lodi Dodi
Nov 12, 2010 06:26 PM
rivers12345
Sep 14, 2008 12:26 PM
CuppednFallin
Jul 21, 2006 09:23 AM
