1998 Blazer LS numerous problems. Exhaust, burning rich etc
Have a 98 Blazer LS 4x4. It burns really rich, you can smell it right off the bat. The exhaust rattles, like inside the muffler. Has troubles starting up after driving for a couple miles. When it does start it just bogs and finally turns over into a rough idle. If the car idles in Park for over 5 minutes the service engine light comes on. Just wondering if there could be multiple problems or maybe just one source. Thanks a lot!!
Agreed, it sounds like the cat is bad but you need to figure out what killed it first. Usually running rich is what does it. Without fixing the rich condition you will only destroy another cat and you probably have pretty bad fuel economy right now.
A number of things, the two most likely are either a leaking fuel pressure regulator or leaking injectors. You can look down the passenger side of the throttle body. If it looks really clean and shows signs of washing then you know you have a leak.
jumpinjimmy
04-03-2014 09:48 PM
buddanicholson101
08-06-2010 08:49 PM
jp's95Blazer
10-04-2009 10:22 AM
